ECI Valve guide problems
3958v
Post by 3958v »
I have a C145 with 365 hrs SMOH with new ECI cylinders and I have had 2 valve guides go bad and was wonering if any one else was experiencing the same problems. Bill K
Curtis Brown
Post by Curtis Brown »
Yeah, I had some problems with exhaust valves. Giving me low compressions. They fixed two of them under warranty less than 100 hrs. after overhaul. Then I had another one do the same after 180 hrs and they paid for that. Then a stucking valve this summer with about 350 hrs. I replaced and the valve and I paid for it. It is a crime that aviation engines will not operate trouble free like my rice burning car engine.
Curtis
1950 A model 1256D
Now you tell me! :wink: I have 6 new ECI Titans in the box awaiting some very slow parts overhaulers and suppliers so I can assemble the engine.
Are the ones having problems Titans, or Classic Cast?
Dave Clark
Post by Dave Clark »
There is a big AD that just came out on ECI cylinders for the Lycoming parallel valve O-360/540. The problem is cylinder cracking with some 30 failures in flight. Since I didn't build my current engine I had to run to the hangar to check mine out. Turns out I have Superior, whew 8)
Sorry Miles but it does seem that ECI might have a bit more problems than most.
N92CP ("Clark's Plane")
1953 C-180
N170BP
Post by N170BP »
Some well-known overhaulers take brand new cylinders (no matter
where they come from) completely apart and "blueprint" them before
hanging them on a customer's case (I think Quack does this).
I have heard it is said that they always find "something" wrong that,
un-corrected, would likely cause a warranty condition/problem down
the road....
Bela P. Havasreti
'54 C-180
Joe Moilanen
Post by Joe Moilanen »
For what it's worth I had 3 exhaust valve guides go bad in the first 200 hours on Superiors. One was after only 25 hours.
Dave Clark
Joe Moilanen wrote:For what it's worth I had 3 exhaust valve guides go bad in the first 200 hours on Superiors. One was after only 25 hours.
Yeah Joe, Ford vs. Chevy :) Relax Miles, the reality is you pays your money and takes your chances.
1953 C-180
I have the ECI "Classic Cast" cylinders on mine. I have had one stuck exh valve (last summer) in about 800 hours of operation. I reamed the guide in place, after removing the valve via the rope trick. No further trouble.
Miles if I were you I'd probably want to take off the valve springs and at least look to see the valve guides are reamed to the tight tolerance.
3958v
Post by 3958v »
Miles I suspect you may be fine. I would be surprised if they did not come up with the Titans for no good reason. I think I may replace one side of mine with the Titans and leave the other side go till I have more problems. I have two bad ones now and one of them was rebuilt 85 Hrs ago so I am not rebuilding any more as that costs half the cost of a new cylinder and has no warranty. I was going to try another brand but they seem to be having their problems too. Sure seems sad that after 60 years we cant be doing a better job. Bill K
