I have a fuel selector that leaks would you believe when in the OFF POSITION. When in the ON or Both position nothing wrong. I guess its in need of a rebuild. Can anyone help with where I can obtain the parts required. I believe a gasket and four O ring's?
Items as listed in Cessna PARTS BOOK PAGE 106:
-7 O-ring, AF934
-10 Gasket,m 0513125
-13 O-ring, AF913-1D
-16 O-ring, AF934-7
-19 O-ring, AF934-14
Should the Ball & spring be replaced also?
Any tips appreciated.
Acft N8109A, Serial # 20961
FRED
35KY
Fuel Selector "rebuild"??????
- N2255D
Look here http://cessna170.org/phpBB2/viewtopic.p ... or+rebuild
and you should have all the info you need.
Walt Weaver
Spencer Airport (NC35)
FUEL SELECTOR REBUILD
THANK YOU FOR YOUR REPLY.
FRED
FRED
