Part number needed
Kyle
Part number needed
Post by Kyle »
Good morning everyone,
I'm looking for some part # assistance. One of our members was able to supply me with the Cessna type oil filter adapter (Thanks John :)). The main o-ring needs to be replaced prior to installation.
Miles was kind enough to send me a link for a possible part # and source but we are not 100 % sure it's the correct one.
Info from Miles was as follows:
Most likely the o-ring Spruce advertises at - http://www.aircraftspruce.com/catalog/e ... radptr.php is the right one, but I have no way to be sure.
According to his 337 form, the Cessna Kit number is A.K.172-112D, and the part number for the adapter is C294505-0101.
DOes anyone have the Cessna part # ?
Thanks in advance .....
Kyle
Kyle Takakjian
Truro, MA
52 C-170B, N8087A
Any Cessna distributor should be able to help you. Try Yingling (800.854.2647) or Hill Aircraft (1-800-998-7832).
Why not just take the accessory to a rubber company store and have them fit it with an "O" ring suitable for the conditions in which it will be used. "O" rings are sized by diameters and cross section and are made of different materials for use in different conditions. The two rubber companies here in Sacramento are able to accomodate almost every situation.
And truth be known, fellas, Sacramento ain't the most sophisticated city.
