Exhaust stack clamps?
Can anyone tell me where I can find replacement exhaust stack
clamps (these are a two-piece affair and clamp the straight/stock
exhaust stack to the bottom of the mufflers). This is for my
'54 C-170B.
Part # is 0550157-5 (I think that's an assembly part number).
TIA,
Bela P. Havasreti
'54 C-170B N170BP
'54 C-170B.
TIA,
Bela P. Havasreti
'54 C-170B N170BP
And so, will you share the contact info with the rest of us? We all appreciate telephone numbers and email/web addresses whenever a source is found.N170BP wrote:Thanks. I found a set at a place called Aircraft Exhaust Systemsgahorn wrote:Wag Aero, Cat. No. E-505-007, $28.70 per set. 800/558-6868
back east (the Wag Aero price is a little cheaper though....).
Bela P. Havasreti
'54 C-170B N170BP
Oops, sorry.... The receipt is at home and I'm off campus. I'll postgahorn wrote:And so, will you share the contact info with the rest of us? We all appreciate telephone numbers and email/web addresses whenever a source is found.N170BP wrote:Thanks. I found a set at a place called Aircraft Exhaust Systemsgahorn wrote:Wag Aero, Cat. No. E-505-007, $28.70 per set. 800/558-6868
Bela P. Havasreti
'54 C-170B N170BP
the contact info as soon as I can get my hands on it.
Bela P. Havasreti
'54 C-170B N170BP
I'm a little late (been gone all weekend) but here is
the source info for the exhaust stack clamps I obtained:
On the receipt, it says that "Aircraft Exhaust Systems
was acquired by AWI"
so here's the contact info:
Aerospace Welding Minnieapolis, Inc
12124 12th Ave. South
Burnsville, MN 55337
1-800-597-4315
(952) 890-1511
Fax: (952) 890-6256
The receipt says they also have an operation
in Florida but it doesn't give a Florida address or
phone numbers.
The clamps were $19.20 each for the ones with the
locating/indexing pin and $7.05 each for the "plain"
clamps.
Bela P. Havasreti
'54 C-170B N170BP
1-800-597-4315
(952) 890-1511
Fax: (952) 890-6256
phone numbers.
clamps.
Bela P. Havasreti
'54 C-170B N170BP
Bela,as long as you're buying stuff ( remember,a $100 bill instead of a $500 bill!), WagAero also sells extended tailpipes for the H-W system on 170/172's. Replaces the stock tailpipe,sticks out a bit farther to eliminate the soot on the cowl behind the tailpipes. P/n E-420-000,$136.75 a pair.
A half-page ad in a recent TAP sez "Radial Exhaust Systems,Jumping Branch WV,formerly Aircraft Exhaust Systems". So maybe they only do radial exhausts now,& sold the tooling for other systems to AWI ??
How did it go in that other thread? About being frugal....
My exhaust stacks look like they're darned near new
(they were probably replaced during the engine overhaul
150 hours ago).
Rule #1 in aviation: If something ain't broke, don't fix it!
Thanks for the part #'s though!
Bela P. Havasreti
'54 C-170B N170BP
150 hours ago).
Bela P. Havasreti
'54 C-170B N170BP
