Instrument panel support attachment
- n2582d
I have a '52 C-170B. It is missing both instrument panel braces that tie the stationary instrument panel to the firewall. (These can be seen on pg. 36 of the IPC -- fig. 19-50, p/n 0513000-6). Could someone describe them? Are they 1/2" "U" channels? angles? Where do they attach at the firewall? I couldn't find any holes in my firewall that would correspond. Are they riveted to the top firewall angle, fig. 19-3&4? Any help would be appreciated.
Gary,
They are not a "U" channel, but rather a 90deg. angle with a tab that folds down at each end to provide an attach point.
Below are links to some photos from when I refurb.'d my '52 B. Hopefully they'll help.
http://www.damowry.com/images/projc170/panel01.jpg
http://www.damowry.com/images/projc170/panel02.jpg
http://www.damowry.com/images/projc170/004_NR.jpg
http://www.damowry.com/images/projc170/panel04.jpg
http://www.damowry.com/images/projc170/panel06.jpg
- n2582d
Doug,
Thanks for the quick reply. The last picture was especially helpful. It appears that your installation differed from the IPC. The brace in the picture attaches to the outboard tab on the panel whereas the IPC shows that it attaches to the inboard set of tabs. Edit: I think the brace attaches to the panel next to the control yoke ball. See fig. 38-6 in the 170B IPC.
