Oil Pressure relief spring
Bill Hart
Post by Bill Hart »
Can some one tell me the part number and a source for a new oil pressure assembly?
Bill if your looking for the spring it's #637083 the plunger is #21114 and the acorn nut is #21113.
I bought the spring for $6.13 from http://www.aircraft-specialties.com/. They have the plunger for $44.53 they don't seem to have the acorn nut
CessnaParts.com http://www.cessnaparts.com has all three at the following prices: #637083 @ $9.94, #21114 @ $61.07 and #21113 @ $91.54
Preffered Airparts http://www.preferredairparts.com has 117 used nuts #21113 and 12 #21114 plungers and they generally sell new parts for half list and used parts even cheaper
Oil Pressure Relief Valve Spring: part number 637083 .
Oil Pressure Relief Valve Plunger: part number 21114 .
Try entering the part numbers at Premier Aviation.
You can also try Superior Air Parts.
cessna170bdriver wrote:Oil Pressure Relief Valve Spring: part number 637083 .
WHAT? You forget to recommend Premium Aircraft Parts? :lol:
lowNslow
Post by lowNslow »
Are these part numbers for the O-300 or the C-145, which seems to require a lower oil pressure?
They are for every Continental from the A65 through the 0-300-D and maybe more but I don't have a parts manual for the rest.
:evil: :evil: :evil: :evil:
lowNslow wrote:Are these part numbers for the O-300 or the C-145, which seems to require a lower oil pressure?
Using a new spring and plunger of the above part numbers, with the original cap (along with a major overhaul), my O-300A’s oil pressure indicates between 53 and 57 psi (Phillips 20W50), depending on temperature. The gauge pics were taken at 0.2 and 0.5 SMOH, respectively.
Image Image Image
What rpm?
Bill Hart
Post by Bill Hart »
Thank you every one. And I wouldn't touch Premium with George's ten foot pole :D
gahorn wrote:What rpm?
2650 in these photos, but the oil pressure doesn't seem to vary much as long as RPM is in the cruise range.
lowNslow
Post by lowNslow »
cessna170bdriver wrote:Using a new spring and plunger of the above part numbers, with the original cap (along with a major overhaul), my O-300A’s oil pressure indicates between 53 and 57 psi (Phillips 20W50), depending on temperature. The gauge pics were taken at 0.2 and 0.5 SMOH, respectively.
Same here, but according to everything I can find it should be 30-45 psi for a C-145.
N2865C
Post by N2865C »
Karl,
I don't have the overhaul manual and parts catalog in front of me, but I believe the specs and the oil pressure relief part numbers are the same for the O-300A and the C-145 (better double check me on that). I had questions about my high oil pressure in my O-300A and this is the answer I got http://cessna170.org/phpBB2/viewtopic.p ... l+pressure
Makes sense to me.......
N2865C
Bill Hart
Post by Bill Hart »
Check out this thred high oil press
http://www.cessna170.org/phpBB2/viewtopic.php?t=1246
lowNslow
Post by lowNslow »
Both of these threads indicate an O-300. The TDC indicates a oil pressure of 30-40 psi for both the O-300 and C-145. The Operators Manual states a oil pressure of 30-45 psi for the C-145 and 30-60 psi for the O-300. These are old sources - the TDC is dated March 1974 and the Ops. Manual is undated is undated but seems to be around the same vintage. I am just looking for some official documentation with updated allowable oil pressures if one exist.
