Oil Pressure relief spring
Posted: Tue Sep 26, 2006 8:08 pm
by Bill Hart
Can some one tell me the part number and a source for a new oil pressure assembly?
Posted: Tue Sep 26, 2006 10:43 pm
Bill if your looking for the spring it's #637083 the plunger is #21114 and the acorn nut is #21113.
I bought the spring for $6.13 from http://www.aircraft-specialties.com/. They have the plunger for $44.53 they don't seem to have the acorn nut
CessnaParts.com http://www.cessnaparts.com has all three at the following prices: #637083 @ $9.94, #21114 @ $61.07 and #21113 @ $91.54
Preffered Airparts http://www.preferredairparts.com has 117 used nuts #21113 and 12 #21114 plungers and they generally sell new parts for half list and used parts even cheaper
Posted: Tue Sep 26, 2006 11:14 pm
by cessna170bdriver
Oil Pressure Relief Valve Spring: part number 637083 .
Oil Pressure Relief Valve Plunger: part number 21114 .
Try entering the part numbers at Premier Aviation.
You can also try Superior Air Parts.
Posted: Tue Sep 26, 2006 11:31 pm
cessna170bdriver wrote:Oil Pressure Relief Valve Spring: part number 637083 .
WHAT? You forget to recommend Premium Aircraft Parts? :lol:
Posted: Tue Sep 26, 2006 11:38 pm
by lowNslow
Are these part numbers for the O-300 or the C-145, which seems to require a lower oil pressure?
Posted: Tue Sep 26, 2006 11:51 pm
They are for every Continental from the A65 through the 0-300-D and maybe more but I don't have a parts manual for the rest.
Posted: Wed Sep 27, 2006 3:48 am
by cessna170bdriver
:evil: :evil: :evil: :evil:
Posted: Wed Sep 27, 2006 4:15 am
by cessna170bdriver
lowNslow wrote:Are these part numbers for the O-300 or the C-145, which seems to require a lower oil pressure?
Using a new spring and plunger of the above part numbers, with the original cap (along with a major overhaul), my O-300A’s oil pressure indicates between 53 and 57 psi (Phillips 20W50), depending on temperature. The gauge pics were taken at 0.2 and 0.5 SMOH, respectively.
Image Image Image
Posted: Wed Sep 27, 2006 6:14 am
What rpm?
Posted: Wed Sep 27, 2006 1:54 pm
by Bill Hart
Thank you every one. And I wouldn't touch Premium with George's ten foot pole :D
Posted: Wed Sep 27, 2006 2:14 pm
by cessna170bdriver
gahorn wrote:What rpm?
2650 in these photos, but the oil pressure doesn't seem to vary much as long as RPM is in the cruise range.
Posted: Wed Sep 27, 2006 4:03 pm
by lowNslow
cessna170bdriver wrote:Using a new spring and plunger of the above part numbers, with the original cap (along with a major overhaul), my O-300A’s oil pressure indicates between 53 and 57 psi (Phillips 20W50), depending on temperature. The gauge pics were taken at 0.2 and 0.5 SMOH, respectively.
Same here, but according to everything I can find it should be 30-45 psi for a C-145.
Posted: Wed Sep 27, 2006 4:40 pm
by N2865C
Karl,
I don't have the overhaul manual and parts catalog in front of me, but I believe the specs and the oil pressure relief part numbers are the same for the O-300A and the C-145 (better double check me on that). I had questions about my high oil pressure in my O-300A and this is the answer I got http://cessna170.org/phpBB2/viewtopic.p ... l+pressure
Makes sense to me.......
Posted: Wed Sep 27, 2006 5:08 pm
by Bill Hart
Check out this thred high oil press
http://www.cessna170.org/phpBB2/viewtopic.php?t=1246
Posted: Wed Sep 27, 2006 5:24 pm
by lowNslow
Both of these threads indicate an O-300. The TDC indicates a oil pressure of 30-40 psi for both the O-300 and C-145. The Operators Manual states a oil pressure of 30-45 psi for the C-145 and 30-60 psi for the O-300. These are old sources - the TDC is dated March 1974 and the Ops. Manual is undated is undated but seems to be around the same vintage. I am just looking for some official documentation with updated allowable oil pressures if one exist.
