Titan cylinders
clayton991
Titan cylinders
Post by clayton991 »
Looking at a new top job, considering Titan Cerminil cylinders. Any reason to avoid them?
steve grewing
Post by steve grewing »
I have 'em and have had no problems in the 120 hours since installation. The engine has averaged 30 hours between adding a quart of oil. I used ECI's break-in procedure using Shell mineral oil for the first 10 hours. Phillips X/C 20W/50 thereafter.
Steve
clayton991
thanks
Tom Downey
Post by Tom Downey »
steve grewing wrote:I have 'em and have had no problems in the 120 hours since installation. The engine has averaged 30 hours between adding a quart of oil. I used ECI's break-in procedure using Shell mineral oil for the first 10 hours. Phillips X/C 20W/50 thereafter.
Steve
OBTW, that is not the ECI recommended break in lubrication.
read
http://www.eci2fly.com/pdf/BI07-2005.pd ... rks&page=5
Tom Downey A&P-IA
dacker
Post by dacker »
I just put 150 hours on my new rebuild with the Titans since Oct 01 last year... I am also getting in the vicinity of 30 hours per quart. I will get my annual at the end of the month and post the compressions.
David
clayton991
great. thanks.
Tom Downey
The engine I built useing ECIs is about the same with 75 hours per year.
Tom Downey A&P-IA
N171Q
Post by N171Q »
I just had a bad deal with the carburator on a Titan overhauled engine.
We've just installed an O360 that was overhauled in 1999 and never taken out of the crate. We did our first leak check run up last week and the mixture had no effect, (no cut off at full lean.) I took the carb in to a shop here and they found not only the mixture linkage installed incorrectly, but the trhottle linkage had not been cottered, there was plastic gunk attached to one of the check vavles, and the float had an AD on it.
I don't know when the float AD came out, but the log entry detailing the engine overhaul says the carb was disassembled, inspected, and reassembled with new components.
I'm the third owner since the purchase of the engine from Titan, so I doubt I have any recourse with them... just bad luck for me I guess, but it set me back some considerable cash! Anyone else heard of this kind of thing with Titan?
'56 C-172 180hp Tailwheel Converted
dacker
Post by dacker »
171Q, are we talking about the same Titan? I am referring to the Titan cylinders made by ECI. I didn't know that they actually did overhauls or do they?
David
N171Q
Post by N171Q »
Oops. Sorry 'bout that. My overhaul was from Titan Aircraft Engines out of LaMarquette, TX. Not ECI's Titan cylinders. I jsut saw Titan and started typing... :oops:
N171Q wrote:Oops. Sorry 'bout that. My overhaul was from Titan Aircraft Engines out of LaMarquette, TX. Not ECI's Titan cylinders. I jsut saw Titan and started typing... :oops:
Umm... did you also perhaps mean Titan Aircraft, La Marque, TX? :wink:
dacker
Post by dacker »
Earlier I said that I was getting around 30 hours per quart with my Titans, today I checked and found my oil at 6 1/2 quarts, I started out at just over 7. This is after 42 hours on the tach. Before rebuild I was getting 4 hours per quart... this is almost scary!
8O David
kloz
Post by kloz »
I have over 1000 hrs on the steel Titans. No problems. :D
Carl
HA
Post by HA »
my first blown engine as a pilot was in a Twin Comanche, it never burned any oil either. turned out it was replacing the oil with metal from the lifters and cam :twisted:
'56 "C170 and change"
'52 Packard 200
'68 Arctic Cat P12 Panther
