changing seats
- DonnieR
changing seats
will a 172 rear seat fit in a 170a
Insufficient data, hard to say. 172's rear seats changed over the years and later seats will not fit. You'll likely have to try it to see, but it's doubtful if any 172 rear seat, especially beyond 1962 will fit.
- DonnieR
I am in the middle of restoring my A model and was changing the nutplates under the floor when it occured to me that the rear seats I have taken out of 172's at annual time bolt in at the same locations and use the same bolt sizes as the nutplates I was replacing. It would be nice to do away with the four brackets for the old seat, and install a newer seat with headrest.
my rear center nutplate got messed up so nowadays I just use a bolt and nut, that will work until my arm gets too fat to reach
I don't know if the newer seats will fit but if they do nothing would change with the mounting scheme anyway
'56 "C170 and change"
'52 Packard 200
'68 Arctic Cat P12 Panther
'52 Packard 200
- bradbrady
Re: changing seats
Donnie,DonnieR wrote:will a 172 rear seat fit in a 170a
Dad has an entire 1966 172 interior in his 1953 170, all work was done on field approvial in the early 70's, It will fit, but good luck geting the paper work through your FSDO now!
brad
