Cost for a used mccaulley prop and 0-300D with 350 SMOH?
Hi all,
I was looking for a friend for a mccaulley prop (can be used) and a 0-300D with 350SMOH. He wants to know what something like this would run. About $8000 for the engine or so or is that too much?
It depends on the condition of everything. Is it a sea plane prop or a standard prop. Is the propeller on its last recondition or has it never seen a file.
The engine i think it would depend on as well. I think a 350hrs smoh with new cylinders at overhaul, overhauled by a reputable shop with tags for all the installed parts or other documentation. Does it have ACC with overhauled or new documentation at overhaul. Ohhh and when was the date of the overhaul 350hrs ago 25 years back or a couple years ago. I think if it met all those conditions on the positive side it would be worth much more then 8k if not then maybe a bit less.
I think I totatally screwed up my orginal message. I am trying to sell this to a friend, but I don't know what it is resonably worth. My plan is to bring the aircraft down for some serious (sheet metal-work) and then sell the engine prop and over the next few years do a 180 hp or 210 or 220 hp upgrade. Anybody know what I should be charging for the engine as a whole and the prop (seperately)? Thanks Sorry for the crappy explanation initially.
If you're giving/selling it to a "friend"...it depends upon how much you value the friendship as to what you charge him. This engine has a per-hour value of about $10/hr. A zero SMOH engine (exchange, no accys) is worth about $18,000. A mid-life engine is worth about $9K, exchange. Core value is about $2K-$4K depending upon mod status. IMHO
(Please observe our rules regarding non members advertising here. This msg very closely resembles the sort of "question' that some participants practice to get around the rules,... "Hey, I've got a gizmo for sale, but don't know what to ask for it!"....but you're not a new-comer to our forums so you have a bit more credibility than most. Consider joining!)
