Parting out old engine?
Posted: Sat Apr 28, 2007 2:27 pm
Dear fellow members:
I found another C145-2 for my plane (see "Need New Engine" thread) so I thought I'd start another quiry as to how best to recoup some costs from my C145-2 with the hole in the case. The engine is 2293 TT, 1250 SMOH, 600 STOH. I have no idea if the crank was ground at the major overhaul.
The only damage to the engine is the hole in the case. It appears no metal went into the engine and even the cylinder that came lose as a result of whatever problem caused the lug to shear and break the case has no apparent damage.
So, what are some ideas about the easiest and least expensive way to go about recouping some money by parting out this engine? Should I disassemble it and send the major parts such as the crankshaft to someone like Aircraft Specialty to see if these parts can be yellow tagged? I'm being told that a yellow tagged 8 bolt crank can fetch anwhere between $2,500 and $3,500, assuming someone needs it. Should I keep my old oil pan as I've heard those are hard to find and corrode, or, are they usually repairable?
Basically, I'm looking for thoughts on what parts from my old engine I should keep because they are relatively rare and likely to be needed in the future, and what parts I should try to sell due to their relatively high value (if they are serviceable) and I will be unlikely to need them?
Or, should I just keep the entire engine as it is identical to the new one I've purchased and just canibalize parts off of it as needed in the future. If I go this option, should I disassemble the engine and clean and oil all the parts, and store them where they won't rust, or, should I just leave the engine in-tact?
Curt
Curt
