Fuel flow
Fuel flow
I am interested in getting fuel flow input from other members. We have a 53 170 B and I am burning 9 g.p.h. leaned without the use of an E.G.T. .All that I read is closer to8 G.P.H. rather than 9 . The compression is good on all cylinders . Mark
Mark
- N1478D
Mark, I use 9 GPH in my flight planning for my 51 A with the C145. I never actually burn that much, it is a safety fudge factor. I am guilty of not knowing exactly how much per hour I am burning - have a clock on the yoke and it starts at 3 hours and when it counts down to 0, I am on the ground, or if either gauge reads empty. I usually have to put in less than 27 gallons, depending on the type of flying that I have been doing.
51 C170A
Grand Prairie, TX
51 C170A
Grand Prairie, TX
Fuel flow
My fuel burn runs about 8 gph in my '53 model, with O300C and EM7655 prop and single-piece venturi carb, at 2450 RPM, leaned but on the rich side, without EGT. With that cruise prop, I'm probably pulling more manifold pressure than 65%. I flight plan 10 gph for a fudge factor. When I get my MP and EGT guages for my birthday, I'll let you know more specifics. (May 22, incase anybody wants to remind Jamie or contribute.)
- N1478D
Re: Fuel flow
That is very interesting! The later part of May is when most turtles are borngahorn wrote:My fuel burn runs about 8 gph in my '53 model, with O300C and EM7655 prop and single-piece venturi carb, at 2450 RPM, leaned but on the rich side, without EGT. With that cruise prop, I'm probably pulling more manifold pressure than 65%. I flight plan 10 gph for a fudge factor. When I get my MP and EGT guages for my birthday, I'll let you know more specifics. (May 22, incase anybody wants to remind Jamie or contribute.)
51 C170A
Grand Prairie, TX
51 C170A
Grand Prairie, TX
Re: Fuel flow
Actually that's when most deer and cheetahs are born. (Not the cheatin' kind, ...the fast kind."N1478D wrote:That is very interesting! The later part of May is when most turtles are borngahorn wrote:My fuel burn runs about 8 gph in my '53 model, with O300C and EM7655 prop and single-piece venturi carb, at 2450 RPM, leaned but on the rich side, without EGT. With that cruise prop, I'm probably pulling more manifold pressure than 65%. I flight plan 10 gph for a fudge factor. When I get my MP and EGT guages for my birthday, I'll let you know more specifics. (May 22, incase anybody wants to remind Jamie or contribute.)
- n3833v
Re: Fuel flow
Re: Fuel flow
So, you're suggesting that ours will be yet another race between the turtle and the Harris?N1478D wrote:That is very interesting! The later part of May is when most turtles are borngahorn wrote:My fuel burn runs about 8 gph in my '53 model, with O300C and EM7655 prop and single-piece venturi carb, at 2450 RPM, leaned but on the rich side, without EGT. With that cruise prop, I'm probably pulling more manifold pressure than 65%. I flight plan 10 gph for a fudge factor. When I get my MP and EGT guages for my birthday, I'll let you know more specifics. (May 22, incase anybody wants to remind Jamie or contribute.)
- N1478D
Re: Fuel flow
It took you a while, and two trys, and two days, but you hung in there and came up with a replygahorn wrote:So, you're suggesting that ours will be yet another race between the turtle and the Harris?N1478D wrote:That is very interesting! The later part of May is when most turtles are borngahorn wrote:My fuel burn runs about 8 gph in my '53 model, with O300C and EM7655 prop and single-piece venturi carb, at 2450 RPM, leaned but on the rich side, without EGT. With that cruise prop, I'm probably pulling more manifold pressure than 65%. I flight plan 10 gph for a fudge factor. When I get my MP and EGT guages for my birthday, I'll let you know more specifics. (May 22, incase anybody wants to remind Jamie or contribute.)That explains why you didn't finish the one last weekend.
51 C170A
Grand Prairie, TX
51 C170A
Grand Prairie, TX
Re: Fuel flow
'George The Turtle' might not stick, if you can speed that B model up. Did you give up being a deer or cheetah, that was kind of confusing, maybe take off like a deer, and fly like a cheetah, or something
[/quote]
Yawwn! Zzzzz.
Yawwn! Zzzzz.
