door lock cylinder gone missing
sloPoke
Post by sloPoke »
Anyone know the best place to pick up a door lock cylinder. 1955 170, but I think they are probably all the same.
Thanks,
Charlie
Charlie
If your door lock is anything like mine you might try looking at the hardware found on most steel locking cabinets with similar barrel locks. Chances are you might find the perfect fit as they seem to be just common lock hardware. Of course the tumblers would have to be changed if you want it to match your mag switch key.
Of course hardware stores and locksmiths would also be sources.
Last edited by Bruce Fenstermacher on Sat Aug 04, 2007 4:38 pm, edited 1 time in total.
Trng wheel (N2625U)
Post by Trng wheel (N2625U) »
A local locksmith can do all of the above for you. I found one that matched up the tumblers and everything. Of course it might have helped that he has a 172 and understands.
sloPoke
Post by sloPoke »
Thanks - I'll check out the local lock guy.
Charlie
Very common lock. I once had a desk key from work that I could also use on '98C.
