Rudder Pedal Bearings
Posted: Sun Aug 05, 2007 9:31 pm
by simon
What are you guys using on the rudder pedal bearings (part #s 0411263 and 0411264) for lube? I figured that normal grease or oil would just collect dirt. As I recall, the service manual is fairly vague on the subject.
Posted: Mon Dec 24, 2007 3:23 am
by SUNDBY
Any help with this? I'm getting ready to reinstall the pedal assembly. Sundby
Posted: Mon Dec 24, 2007 8:57 pm
Don't know if there is a right lubricant. Almost anything you use with the exception of a dry lubricant would eventually hold dust and dirt.
What would I use. Something I had around the shop. A small dap of wheel bearing grease or white grease. I might use a drop of 30 weight motor oil or even a shot of LPS2.
