What hone to use to cut glaze and prep cylinders
I'm reinstalling my cylinders on my Cub and using new rings. I of course want to hone the cylinder to cut the glaze and prep the cylinder to break in the new rings.
What type of hone are those that have done this using. A 3 stone cylinder hone? A ball or flex hone? What grit? What abrasive?
These cylinders are chromed if that makes a difference.
If you're just breaking the glaze and cleaning up the cylinders for a "Top", a "Dingleberry" hone seems to work best for me on this kind of job.
Yes BL before the world with the internet with more information than you want at your finger tips I would have just gotten a "dingleberry" hone (what a technical name 8) ). they are also known as "Ball" or "Flex" hones.
But alas besides several names they now come in several flavors ie abrasive types and grits.
Yes I'm just breaking the glaze for a reinstall with new rings after a tear down and rebuild to replace the crank, 75 hours after overhaul. (eeerrrrrrrr)
mrpibb
Post by mrpibb »
Hey Bruce, a 4" flex hone or a tad smaller for the A series would do the trick, on a chrome a quick hit with a 240 grit along with honing oil should suffice. make sure the cylinder is cleaned thouroughly before assy (but you know that).
Vic
N2609V
48 Ragwing
12N Aeroflex
Andover NJ
Thanks Vic. I bought a 4 1/8" flex hone 240 grit but have yet to use it. C-85s which is the engine cylinders I'm doing have the same bore as our C-145 at 4.065". The 4 1/8th" flex hone has a range of 4" to 4 1/8th".
A pretty good article for break in (including notes about channel-chrome) is: http://occonline.occ.cccd.edu/online/rf ... 0Right.pdf Another is: http://www.shell.com/static/aviation-en ... 2_2007.pdf
Use mineral (non-AD) oil and run it hard until consumption stabilizes and cyl. head temps fall.
Channel-chrome is made by short periods of electrolysis current-reversal. Don't be too aggressive with re-honing. All you want to do is remove any existing glaze.... not actually polish channels out .... or remove chrome material. (Flood the cylinder with safety-solvent while honing. Do not use flammable solvent. Keep a good "up-and-down" movement during honing to produce a "figure-8" pattern in the cylinder. Don't over-do it when honing. Just rough it up a bit. Ten-seconds is a lot.)
