O 300D Engine logbook
- N2255D
I have an engine log for an O300D that came with 55D when I bought it. The log starts in 1964 and ends in 1970. It was on 55D from 1967 to 1970 when it was replaced with a new O 300D. Whoever removed the engine did not send the log with the engine. I posted this once before on the CPA site and was told to just throw it away but I put it away and forgot about it until I just came across it. Thought I would see if anyone here is missing a log.
Walt Weaver
Spencer Airport (NC35)
Walt, my plane got an O-300-D engine about that time.
What is the serial number of that engine?
- N2255D
Sn 28441 D-3-D
The log book shows an oil change 7-24-70. That is the last entry except for the install of a strobe light per STC on 5-12-72. and then a scribbled out entry of an aircraft annual 5-18-74. The airframe just says removed the above engine and then reinstalled factory remanufactured engine with a description of the install.
Walt Weaver
That might explain it. If it were exchanged for a factory reman, then the engine got a new logbook when TCM remfr'd it. and then it would have no previous "service history". The old log would be tossed.
If it were me, I'd keep it with my airframe records.
