How do you remove the interior door panels? I have an Airtex interior installed and I can find no obvious fasteners. I assume that there are clips that can be pulled loose but I wanted to ask before I pulled something loose that I should not...pull loose. Thanks.
Bruce
Door Trim Panels
Door Trim Panels
Bruce Shipp
There are clips like automotive trim of the old days.
Use a putty knife and slip it under and slide till you find a clip then pry carefully near or on the clip.
