Can of you ragwing guys tell me if there is a grommet or anything around the pitot tube as it comes through the leading edge? If not, how is it installed?
Thanks.
-Dustin
Ragwing Pitot Tube Installation
- N4281V
Mine has clear plastic tubing on the tube where pitot tube comes out - I think it had a grommet before we covered the wings...dunno if the part manual says anything - it's not near me, it's 500 (driving) miles away.
Ann W.
1948 Cessna 170
N4281V (sn 18699 - wings) & the former N4147V (sn 18479 - fuselage)
1948 Cessna 170
A 5/16" rubber grommet is installed at that point. It's not difficult. Remove any pitot-cover/protector, slide the lubricated grommet over the pitot tube, and using a small flat screwdriver or pick, insert one edge of the grommet into position and work your way around the grommet until it's fully inserted. Replace the pitot cover/protector. My favorite lubricant for this job? What else? WD40!
That's not the same kind of "pitot tube" we are talking about, DICK!blueldr wrote:WD40 may work OK on that job, but my girl friend has some really amazing cold cream.
And your arthritis goes away.Haydon wrote:bluelder,
Just pour a gallon of WD-40 in the water softner.....no need for cold cream and it keeps the coffee pot real clean......![]()
Richard....
