Recomendation for paint shop in the NE?
Iceman07
Post by Iceman07 »
I can't afford to get the complete airplane done, but I need to get the "new" baggage door painted. Any recomendations for a paint shop in the CT, MA, NY, VT area?
TIA
Rich
N5740C 1950 'A' Model
N2865C
Post by N2865C »
Can you remove the door? If it were me and I just wanted to get the door done I would take it to a local auto body shop. If you take them a fairing or inspection plate that is the right color they can make a perfect match, probably for less than an aircraft paint shop. If you want to do it yourself auto body supply houses (look in the yellow pages) can mix you up a quart if they have something to match. Some can even put it in a spray can..... Sounds funky, but I painted the leading edges of my 120 that way as a temporary solution and nobody could tell the difference. 8 years later it still looked great.
N2865C
doug8082a
Post by doug8082a »
Prestige Aircraft in Swanton, VT (http://www.paintaircraft.com/ )
They did '82A and I wouldn't hesitate to use them again. Great job and real nice folks. Although, it's a long way for you to go for just a baggage door. 8)
When a baggage door is installed, there is uaually some paint work needed on the fusealage around the door opening where the riveting has been done.
Mark Harwood
Post by Mark Harwood »
The shop in Middlebury VT does nice work. J & M aviation if I remember, or look for Middlebury VT FBO in airport directory.
'49 A N9183A
Cossayuna Lake NY
