elevator parts
33alfa
elevator parts
Post by 33alfa »
Can anyone tell me where to get elevator parts. Are the L 19 tail feathers the Same? Im looking for the parts the pork chop hook up to inside the elevator.Round pipe with two spares attached. Thanks -33 alfa. Both sides.
Re: elevator parts
Well 33 alpha
I have no idea what parts your looking for by your description. I also don't know what model aircraft you have, I'll assume it is a 170 but you didn't say.
Parts manuals are available on-line from this link: http://www.micro-tools.com/pdf/Cessna/ Using them makes it so much easier to describe exactly what your looking for,
If you have a 170 or a 170A the elevator parts are the same but not the same as a B model or a L-19. B model and L-19 elevator parts should be the same except the counter weights but B model and L-19s do have different part numbers.
33alfa
Re: elevator parts
Post by 33alfa »
Sorry guys and gals. Let me do this a little better this time. P/N 0334206 Left rib and tube assy and P/N 0334106 right rib and tube assy. Did not have the IPC with me the first time. 33 alfa. are they obtainable.
Re: elevator parts
Looks like they are A model parts and probably hard to find. I seem to remember 4 or 5 years agos someone looking for the same parts and altimitly had them manufactured locally. Good luck.
Kim Purcell
Re: elevator parts
Post by Kim Purcell »
Two years ago I replaced the torque tubes on both sides of my A model and they are very hard to find, it was to a point that we were looking at doing a modification so that we could use a B part. I called all over the country and ended up finding them at a local place. I believe Wentworth was one who had one, last time I was at Ken Feithe he had a complete A elevator, I will probaly be going there within the next week or so and will look for you
Kim
170A
33alfa
Re: elevator parts
Post by 33alfa »
Kim Thanks for your reply. I did not give out good info ie 170A/torque tube as i guess i thought when i said thingy everyone would know what i needed. Ha Ha!. Anyway i lucked out and found a guy in Anchorage that thought he had 140 elevators and i thought maybe they would work. They will not however when he showed them to me guess what? 170 A tail feathers what luck. Im set Thanks Roger
