What is the easiest way get info to the AD's on my 170?
Larry
How do I get a list of ADs for my 1953 170b?
Re: How do I get a list of ADs for my 1953 170b?
You can obtain a list on the FAA web site. Try:
http://www.airweb.faa.gov/Regulatory_an ... enFrameSet
and try the AD Index under Historical AD's
If this link works - Try: http://www.airweb.faa.gov/Regulatory_an ... n%2007.pdf
and use your find function to go to Cessna. Scroll down to 170.
Hope this helps.
Hope this helps.
Bruce
1950 170A N5559C
1950 170A N5559C
You will also have to search for all the 'appliances" like carburetors, magnetos and propellers that could be installed on your airplane.
Right Bruce, I should have mentioned that.N9149A wrote:You will also have to search for all the 'appliances" like carburetors, magnetos and propellers that could be installed on your airplane.
Bruce
1950 170A N5559C
1950 170A N5559C
Unfortunately, even that sort of search will not catch it all. Example: The Cessna 170's with later/other model Cessna seats installed, whose AD notes will be listed under their original installation aircraft ... and nowhere else.
(So if you have any equipment that originated with other aircraft models you have to beware of such substitutions.)
