It does not get above that, until I start to level off after climbing out at 80.
In cruise at full throttle i get 2625 Rpm at 2500ft .
Static full throttle not moving I get 2200 RPM.
I have a C172/EM7655 prop. Prop overhauled 15 hrs ago.
The tach was calibrated in April/08.
Mags check ok ??
Mixture seems OK,.. I get a very slight rise in RPM, when I pull the mixture out to shut down.
Engine has 15 hrs since major overhaul.
I do seem to be getting a little blow-by, or something as I get a very small bit of oil on the windshield every 2-3 hours.
I am running 7 qts of mineral 100 oil.
Any suggestions ??
