Door Latch Spring
Door Latch Spring
Has anyone found a recent source for the Door Latch spring, PN 0411554.
Re: Door Latch Spring
Back in about 1977 I built a jig to wind my own springs out of 20ga./.045"dia music wire which were then tempered in the oven at I think, 450°F for 20 minutes. Those springs are still in the plane today, and still working fine.
Dick,
Did you cold bend and coil the wire or heat it with a torch first?
- Indopilot
You can go to the 120/140 assoc. web site and get the plans to build the jigs. At least you could in the past. Then you cold bend the piano wire. Brian
52 170B s/n 20446
56 172 s/n 28162
Echo Weed eater, Jezebeel
56 172 s/n 28162
You cold bend the wire, it is VERY stiff, then temper it in an oven. DO NOT heat it with a torch.jyaiser wrote:Dick,
Thanks for the good information. If a couple of leads do not come thru in the next couple of days, I will start bending my own.
JY N3437C
JY N3437C
Check out THIS solution submitted to me by one of our members who should speak up and take credit (these springs are available at any good hardware store): CLICK ON PIC TO ENLARGE
George-
That looks like a much better fix than trying to duplicate the original spring. And the latch will still work even when one fails. The originals are fairly hard to make. A trip to the hardware store is much easier and you might see another tool you just can't live without.
I got a response from the 140 spring maker that he is still making the original type spring for $20.
But I do like George's solution much better. I'am off to Ace Hardware.
Thanks again.
JY
Thanks again.
JY
It's not my idea. It 's the ingenuity of one of our members who submitted his solution to me, and I stupidly cannot remember his name. I'd love to be reminded by him so I can give credit.jyaiser wrote:I got a response from the 140 spring maker that he is still making the original type spring for $20.
Thanks again.
JY![]()
- Curtis Brown
My spring on the pilot side door broke about 8 years ago. I found a spring at ACE... had to modify it a little and it is still working. Lowe's may have them also.
Curtis
1950 A model 1256D
1950 A model 1256D
- lowNslow
When I removed my latch for repairs years ago it had the coil springs on it as well, so I guess this technique has been around awhile. I used them on my other door and it does work well but you'll have to experiment with some different spring tensions to get ones that do the trick, so when you go shopping get several different ones to try.
- Joe Moilanen
It was me George,
When I took mine apart to fix it, it looked like the best solution. And it's still working! The springs came from ACE hardware, I wish I could remember what the #'s were but it should be pretty easy to figure out.
4518C
4518C
gahorn wrote:It's not my idea. It 's the ingenuity of one of our members who submitted his solution to me, and I stupidly cannot remember his name. I'd love to be reminded by him so I can give credit.jyaiser wrote:I got a response from the 140 spring maker that he is still making the original type spring for $20.
Thanks again.
JY![]()
THANK YOU, JOE! (I'm going to re-name the photos in my folder so I can remember next time!)
- mongo2
Does anyone have a pic of the underside of a door latch assy, as I have an A model, and I am trying to fit the new mousetrap spring 051119 in, which is really item 43 on a B model. My "A" latch had a similar mousetrap spring but was not as wide and was fitted to the actual half moon latch.
I reviewed the MX library and saw the post and a B model latch diagram, but I just cant seem to get the assy correct. It appears the mousetrap spring was moved aft in the B model, and I am not sure if I can even use it, or where the hooks are set to.
I have new item 38 ,0411567-2 springs and those and they appear to be very strong.
Basically I ordered the part 051119 and assumed it was the same mousetrap spring I was looking for, but failed to see it really doesnt exist in my A model IPC.
Confused? So am I.
Rick
Confused? So am I.
Rick
Rick Champagne
C-170A N5475C
C-170A N5475C
