Wing Fairing Rub Strip
flat country pilot
Post by flat country pilot »
I'm going to replace the wing fairing rub strips. They are almost gone right at the windshield.
Part # 0520005-3 and 0520005-7
Is there a good source to buy them, or should I make some out of felt?
My hesitation with felt, even good quality wool, is that it may not stand up to water.
Bill
Flat Country Pilot
Farm Field PVT
54 C170B
Robert Eilers
Re: Wing Fairing Rub Strip
Post by Robert Eilers »
I replaced mine recently with felt - be careful to get the right thickness of felt - otherwise you will have trouble reinstalling the wing fairing. Felt seems to do the job just fine. I have taped over the leading edge where it joins the wind shield - reduced drafts as well as leaks.
Bill, genuine wool felt is exactly what you need! (And it stands up to years of water just fine.)
flat country pilot
Thank you guys.
Seems like a real minor thing, but it protects the major windshield.
Bill
Flat Country Pilot
Farm Field PVT
54 C170B
HA
Post by HA »
hi Bill, I used some camper tape (2" x 0.25" foam weatherstripping). stuck it to the fairings so it comes off with the fairing when I do inspections but otherwise stays put. works great, cheap, no drafts or chafing.
'56 "C170 and change"
'52 Packard 200
'68 Arctic Cat P12 Panther
propizza
Post by propizza »
Any chance someone has the spec size for the wool?
Ace and True Value Aircrft-Supply sell felt in rolls. Cut it to size.
propizza
Post by propizza »
I was thinking more the thickness, than the length and width
