Fuel guage floats
Jimmy M.
Fuel guage floats
Post by Jimmy M. »
Anyone know where I can get new floats for my fuel guages ?
When I bought my 172 it had sat in a field for 20 years, when I removed the fuel
guages to clean and pressure test the tanks I found the cork floats all shrivelled up
to about half the original size. I guess we're not the only thing that shrivells as it gets older. :D
Thanks...............Jim
Jim Martin
'46 Aeronca Chief, 160 hp ( homebuilt )
'56 170 square tail, 180 hp. :)
Re: Fuel guage floats
I'll bet you didn't try to "search" the forum for this. (grin)
Aircraft Spruce 877-477-7823
Replacement float only, PN 05-03395, for $2.69.
http://www.aircraftspruce.com/catalog/i ... _gauge.php
Jimmy M.
Post by Jimmy M. »
Thanks George,
My project is starting to come together, hope to fly
it this spring.
Jim Martin
there is also the data Steve Grimsley put together re replacing the floats. Common cork will work for these if properly sealed.
jrenwick
Post by jrenwick »
170C wrote:there is also the data Steve Grimsley put together re replacing the floats. Common cork will work for these if properly sealed.
...and for sealing, Poly Fiber 2-part epoxy varnish works well and is not affected by fuel (a tip from the Cub Club folks).
The replacement floats are nitrile and are unaffected by fuel.
