Broken Dorsal Fin forward attach point
learaviator
Post by learaviator »
Well, it would appear that over the years too many people pushed on the fin to move this plane. While doing the annual I noticed that the front of the fin had a little play side to side. After checking the bolt and screw and tightening both nothing changed so I pulled the fin and found the attach point completely broke off. Good time to install my BAS tail pull handle kit I bought. Has anyone had to address this? Did you replace the entire channel? Also finished converting the wing root fairings to screws. Pain in the rear..... Also installed the STC'd cowl latches. I know one of these days I get to fly it!
"You can only tie the record for flying low"
1950 170A N9907A 180hp. STOL
Re: Broken Dorsal Fin forward attach point
PN 0531112-4, (item 31 in Fig 13 of the B-model IPC) is rivetted to the dorsal on both sides. (two bracketts for each airplane). It looks like replacing the bracketts only is the thing to do. You can even make these bracketts under the owner-produced rule.
learaviator
Hi George, actually this is a A model so it has the single attach point underneath the fin. Talked with a friend in the FAA and I think we have figured out a fix without having to replace the entire channel. We will see.....
learaviator wrote:Hi George, actually this is a A model so it has the single attach point underneath the fin. Talked with a friend in the FAA and I think we have figured out a fix without having to replace the entire channel. We will see.....
Well, DOH! I could have/should have noticed that from the pic and the signature!
