G'day All,
My search for a locally available lower panel cover was unsuccessful so I thought I would have a go at making my own.
I got piece of .020" alclad and started cutting and bending. I used some aluminium round stock turned down, ground, riveted and filled for the corners and a dimple die turned up from 1" pipe for the radiused edge on the hole where the yoke comes through....
I am currently in the process of tidying up the right side panel including a new door....
I used the same dimple die to make the recess where the knob goes, not quite as deep as I would like but as deep as I could get without punching out the hole....
here's the old door....
cheers,
Noel
Home Made Lower Instrument Panel Cover
Work : AT502B
Play : '51C170A
Play : '51C170A
Re: Home Made Lower Instrument Panel Cover
Nice work! Always nice to see someone that will learn how to make/do something.
Bruce
1950 170A N5559C
1950 170A N5559C
Thanks Bruce,
I might have opened a can of worms here, I was only going to do the left panel for now but ended up pulling the right one as well. I have plans to do the upper one as well as the rest of the instrument panel. Refurbishing can be addictive!
Noel
Noel
Work : AT502B
Play : '51C170A
Play : '51C170A
Don't forget all those lightening holes in the wing ribs.
(Nice work!)
(Nice work!)
Noel:
Very nice workmanship!
Thanks for sharing.
I have been looking for a door and now might try to make one.
Dan
Thanks for sharing.
Dan
