crankshaft serial number location
canav8
Post by canav8 »
Can anyone tell me where the serial number is located on a crankshaft? Is it actually stamped on the crank or is it just in the paperwork? Thanks. Doug
52' C-170B N2713D Ser #25255
Re: crankshaft serial number location
TCM crankshaft serial numbers are stamped upon the propeller flange, sometimes with an engraving pencil. Look on the outer flange, and/or beneath the prop hub.
From TCM MSB99-3C, Crankshaft inspection: CRANKSHAFT SERIAL NUMBER IDENTIFICATION
Crankshaft serial numbers incorporate a manufacturing date. Crankshafts produced in 1998 may be identified
as follows:
Code:
All crankshafts with serial numbers beginning with the letters A through L (Jan. through Dec.) in the first
position and the year code 98 in the fourth and fifth position are affected. This serial number is stamped on the
propeller flange.
canav8
Post by canav8 »
Thank you george, but this is pre 1998. I will pull the prop. V/R Doug
