Airframe Overspeed Vne
- johnsunday
Is there a mandatory or suggested airframe inspection procedure when you have exceeded red-line airspeed? Engine max RPM?
N2786C, Ratty ole Alaska Bush Plane (google for pix and latest flight tracks) (yeah I fly it IFR)
Re: Airframe Overspeed Vne
I'm not aware of a specific inspection, although there could be one. You would probably notice wrinkled wing skins if there was any damage. I always inspect the rear spar 12" to 24" outboard of the root rib, as a standard part of any inspection opportunity. It doesn't take much of an outboard leading edge strike to kink the rear spar at this location. This is a weak area on older 150, 170,172 wings; much improved on 180 series and up and later models. I've seen the rear spar kink from a wing hitting a hangar at walking speed, and from a bird strike. Both of these incidents were from strikes on the leading edge within 2 feet of the tip, and both only required replacement of the outboard leading edge skin and one rib (the major damage being to the rear spar). I could also imagine rear spar damage if flaps were deployed, or deployed rapidly, at excessive speeds.
Also inspect tail surfaces attach points and aft fuselage skins.
Del Lehmann
Mena, Arkansas
Mena, Arkansas
The airframe should receive an inspection for damage. If you want to do it "per the book" you will have to contact a Cessna Service Center for factory engineering approval.
As for engine overspeed, one must comply with TCM Service Bulletin SB06-2, which is in the MX Library. Here's the link: http://www.cessna170.org/forums/viewtop ... f=6&t=6779
- johnsunday
Many thanks guys.
- Brad Brady
John,johnsunday wrote:Is there a mandatory or suggested airframe inspection procedure when you have exceeded red-line airspeed? Engine max RPM?
How long were you over VNE?......That makes a difference on the type of inspection needed......if any...Red line is something to watch.....not necessarily something to really never exceed
- johnsunday
Brad,
Only lasted for a few seconds, 10 at most. Gonna do Del's inspection recommendation this week-end.
Hmmmm - anyone else reading between the lines on this one?
- Brad Brady
John,johnsunday wrote:Brad,
I only ask, Because I fly an AG plane.... after making a turn at stall speed (200 foot of the ground)....I need to get enough momentum, entering the field, to spray across that field and have enough speed to make the turn at the other end. I know that I'm at or near VNE every time I enter a field......about 200 times a day.....But I'm also preoccupied with watching the light bar and the crop coming up at me at 140- to 160 MPH, so I have no Idea if I over do VNE (I don't watch the airspeed indicator)........I'm sure I don't.....But as I said before it's something to watch........stuff happens. All aircraft are built to take more than is recommended by the color stripes on the airspeed indicator. But it's what your comfort level is, on what you need to do to inspect your aircraft........Brad
- johnsunday
Robert,
Nothing to read between the lines here.....VFR, VMC, got going too fast downhill....
- johnsunday
Brad,
For an old guy, I still have a pretty sharp scan, and for work, I fly airplanes that require various inspections when limits are exceeded and have computers that record that data and send it back to my employer, who in turn, send it on to father FAA. In my youth I was a bold pilot, but as I have gotten old, I have become a cautious pilot, and since I put loved ones in the old bird, I tend to err on the conservative side when it comes to them....
N2786C, Ratty old Alaska Bush Plane
Nice looking 170. Hope inspection turns out well
- Brad Brady
Cool, just throwing in my two cents worth......and apparently that's all it was worth
- johnsunday
Brad,
I appreciate your input! Many thanks...and your input is worth a lot to me!
- johnsunday
voorheesh wrote:Nice looking 170. Hope inspection turns out well
voorheesh,
Thanks, I really do appreciate the old airplane. When I first got it, I remember thinking to myself, "OK, I'm 85 miles from my destination. Gotta think about descent , approach and landing. Only a few minutes from descent." Then I started computing that I was still about an hour away.....
I now have a different perspective....
- Brad Brady
John,johnsunday wrote:voorheesh wrote:Nice looking 170. Hope inspection turns out well
voorheesh,
Everything seems to be all about perspective, Doesn't it?
