Removing exhaust deposits from cowling
What do you guys use to remove exhaust stains and deposits? Even with extended stacks cut off parallel with the cowl, I'm still getting exhaust deposits on the cowling. There has to be something that will remove them without harming the paint.
Re: Removing exhaust deposits from cowling
Try using a file, but be very,very careful.
Robert Eilers
Post by Robert Eilers »
The new less corrosive "Green" Simple Green works fine - just follow it up with soem soap and water.
robert.p.bowen
Post by robert.p.bowen »
Available from Aircraft Spruce, "Greze Off" does an exceptionally fine job. So does "Scrubbin Bubbles" but I'd follow it with water, altho I've never had any staining or corrosion issues and I've used it for 20+ years on painted fabric, fiberglas and metal. But Greze Off does such a good job I've switched to it.
Bob-
Of course this isn't pertinent to your question Richard and I'm sure you will get some good suggestions that will work for you, but a solution I finally found, although not with keeping originality (but my plane left that behind many yrs ago), was the extended exhaust pipes (Bartone or Benham). However I am sure if you wanted to consider that option you would have done so while having Del do his magic on your plane.
PS: What is 50 miles west of Fredericksbury?
Excuse my lack of previewing my spelling :oops: I know its Fredericksburg :!: I need an automatic spell check on my posts :roll:
There is a product called "Hydrosolve" that is made by JetStream. Very good for this sort of thing. I gave some of it away as a prize to a 195 pilot at Reklaw 7 years ago and he now swears by it.
markeg1964
Post by markeg1964 »
I use Extreme Simple Green which was designed to be used on aluminum aircraft. Works great.
Mark
Twin Oaks Airpark
1950 170A N5528C
wingnut
Post by wingnut »
Richard,
I know you are aware of the product Rejex, and have used it. Have you applied it to the cowling to see if the stains are more easily removed after each flight? Or, maybe it "cook" off to quick?
Del Lehmann
Mena, Arkansas
markeg1964 wrote:I use Extreme Simple Green which was designed to be used on aluminum aircraft. Works great.
Warning: The original Simple Green product which was used by the military became condemned by them as attacking aluminum. The Simple Green folks came up with a replacement product which claimed to be OK or "approved" for use on aircraft.
I ordered some to use as a test. It corroded my test-piece and stained my left aileron/flap where it was applied. (When I asked Del's folks how they kept my flaps identified left/right while they were off the airplane for re-skinning earlier this year, Mike specifically pointed to the Simple Green permanent stain as identifying my left flap.)
I complained to the Simple Green folks and was attacked by them for daring to publicly repeat the results of my test. The Simple Green representative even came onto the forums and got very defensive....even abusive, in my opinion.
I do not believe they are anyone from whom I would expect courteous treatment should you later find their product's corrosive effect on your airplane, and therefore I do not recommend Simple Green products on aluminum.
Richard, Joe Harris's solution to stains and oil on the belly was Scrubbing Bubbles. I adopted his suggestion and have been using SB every since when I need to clean my belly panels to remove oil. Works like a charm. Spray on some, let it sit for about 30-60 seconds & wipe off the stuff. Harder baked on may have to have a second coat, but after removing the oil then wipe away the slight haze & the paint shines like new. NOW, you weren't asking for a way to remove oil from your plane's belly, but give it a try on those exhaust stains and see if it doesn't do the job. If not, give it to Ina to use on the faucets as that is what it was designed for. Or maybe cleaning those fixtures is your job :roll: Either way its great stuff and I have not seen any problem with my paint from using it and I have done so now for at least 5 yrs. Good luck.
N2865C
Post by N2865C »
I seem to remember it the other way around... I have used Simple Green for Aircraft and found it to be an excellent product. When the subject came up on the forum and I contacted them for more information I found their customer service to be excellent and very helpful in answering all of my questions....
N2865C
Here's the link to the original thread, (including some of the exchange w/Ms Chapin of Simple Green) which can be read by those interested....or whenever a really slow-day comes around. :wink:
(Those of you with polished airplanes, as I said previously ...beware of using the stuff on the polished areas. It makes a permanent stain on bare aluminum.)
http://www.cessna170.org/forums/viewtop ... mple+green
170C wrote:PS: What is 50 miles west of Fredericksbury?
Frank-
Fredericksburg is 50 miles west of Spicewood/George's place. Somehow it got turned around. Thanks for the scrubbing bubbles tip but I think with the new paint I'm going to try to find an aircraft product that will do the job.
wingnut wrote:Richard,
Del-
I will definitely use Rejex once the cowl is clean (and hopefully with paint still intact). Rejex is specifically made to help keep exhaust stains from sticking to the paint but I did not apply it immediately after the plane was painted and by the time I got home, the cowl was already dirty with exhaust accumulations. Now I need to get the cowl clean before I apply the Rejex.
Ex-Rat-Plane woes. What are you gonna use to keep the bugs and dust off, Richard?
Do you always try to find/leave a vacant tie-down space next to you on both sides? :lol:
