flylow wrote:
What should be my priority for getting this Airplane instrument ready? What do I need? I really don't want to put much money into the panel
I got my instrument rating in my 170 and had a great experience doing it. If you intend to fly your plane IFR after you get the rating, spend the money on your plane instead of rent. Otherwise you'll have a rating and no good way to use it.
My instructor was and is a professional pilot who had me file and fly actual IFR whenever possible during my training. Even without the standard T-panel the scan is easy to adapt. Sure, the T-panel is more, well, standard, but it's not necessary. Look at the hodgepodge shotgun arrangement of instruments on most older planes. But they still flew them, and without modern avionics.
Take a look at the picture (most folks have seen it several times before so no comments from the peanut gallery) and you can see how my panel was arranged in 1979 when I set it up for instruments. I flew it a total of over 150 hours IFR between 1979 and 1984 when it was sold. I bought the plane back in 2006 and upgraded the panel again with Garmin stuff. I still have everything that was taken out of the old panel including two KX-170B's, two KI-209 G/S heads, KN-73 glideslope receiver, KR-22 marker beacon, KA-134 audio panel, and KT-76 transponder (although it was getting weak), all with trays and connectors, plus assorted instruments. I think you would want new antennas and coax. You could spend a little money on an IFR GPS (older, non-WAAS Garmin 430 units are available for much less than WAAS although WAAS is REALLY nice) where the ADF was and have a really functional panel/airplane. Or use a handheld moving map GPS instead of a panel mount but you won't be able to take advantage of the numerous GPS approaches available just about everywhere with the handheld.
If you are interested, PM me and I'll give you a smoking deal on everything, I've been waiting for someone who needs a complete low-cost package instead of parting it out.
As far as advice goes on flying actual IFR, if you stay away from ice, thunderstorms, and fog you'll have a long and happy life. Try to always file into improving or at least stable conditions, never deteriorating conditions. Decide early if you need to deviate or land short of your destination. Always give yourself several options, never let your options go down to one. A moving map GPS and fuel flow computer are the two things that have reduced my IFR anxiety more than anything else.
Good luck.
