And I've had a difficlut time pin-pointing the exact area of the leak. If I run it short time on the ground the leaks don't present themselves for discovery. If I fly it around the patch and land.... the oil is everywhere, including the firewall!
Where,....Oh, WHERE! ...IS the source?
So I went to AutoZone and picked up their least expensive Ultraviolet oil leak detector kit, which consists of an ultraviolet pen-light, some dye (careful.... you want the OIL/HYDRAULIC fluid leak-detector dye, ...not the Freon or fuel dyes),...and some yellow-lens glasses (the better to see the ultraviolet-lighted oil.)
With a fresh oil-change performed, but BEFORE washing the engine down, I added the dye just before adding the last quart of fresh oil to the crankcase. I wanted to make certain the maximum amount of dye was washed down the oil-service tube on the engine and mixed with crankcase oil, so I made certain I followed the dye with a quart of oil, to wash it down.
I ran the engine for about ten minutes at about 1,000 RPM and then pulled the plane back into the hangar, closed the doors and turned off the hangar lights to make it as dark as possible, and took a look with the various areas of the engine that are always wet with oil, illuminated with the ultraviolet penlight and while wearing the yellow glasses.
"Surprise, SURPRISE, Surprise!" - Gomer Pyle
I had thought the oil was leaking from the engine thru-bolts, but the FIRST surprise was the dipstick tube! See the "without UV lighting versus WITH UV lighting" :
I was also surprised by the studs at the tappet-body covers.
An area of the No. 5 cylinder pushrod rubbers stayed wet, but the rubbers looked good, and I thought it would prove
to be the crankcase thru-bolt holding the left, front, engine-mount.
Wrong! An otherwise healthy-appearing pushrod rubber has apparently lost it's elasticity. Although it takes patience, and about a $30 investment in dye, penlight and glasses.... I am glad to know the real culprits in my oil leaks.
Now to FIX them.
I plan to clean the dipstick tube and tappet body cover/stud with solvent, then electronics cleaner, and apply Permatex #2 into the crevices, to stop the oil leak. (I've successfully used this technique on engine thru bolts and cylinder base nuts.) Let the Permatex dry overnight before operating.
The Pushrod rubbers will be replaced using Permatex Oil and Fuel Adhesive on new rubbers, split to wrap around the pushrod housing, and glued/clamped. I'll follow up on this untried procedure to report it's effectiveness.
Meanwhile.... for those of you who want to know the exact source of oil leaks, you might wish to try one of the Ultraviolet Leak Detection kits used and sold by automotive sources.
Even if I don't actually stop the leaks, I am re-assured that the source of oil is determined NOT to be a cracked case or other traumatic problem. I"m just glad to KNOW where that oil is coming from!
Hope this short article is helpful.
PS- It was really hard to take pics thru the yellow lenses of the glasses in order for the UV lighting to show up. Holding the camera, glasses in front of the camera-lens, holding the penlight with the other hand, twisted-up/around to illuminate the leak, and then finding a spare finger to focus, then activate the shutter, was harder than pouring in the dye and running the engine. Someone owes me a beer!
