Hubcaps for 6" Cleveland Wheels
My Cleveland Wheels have 3 screw holes, presumably for mounting some sort of hub cover. Any idea where these covers can be acquired?
Hubcaps
Aircraft Spruce has some very nice aluminum hubcaps complete with the mounting screws for a very resonable price.
Harold H
Mbr # 893
Harold H
Mbr # 893
Hubcaps
The 2002-2003 Spruce catqlog has hubcaps P/N 06-03710 for 600-6 Cleveland wheels for $9.95 each. They have a nice brushed alunimum finish and can be left natural of painted to match your plane. When I bought mine a couple of years ago they were $11.30 each, complete with mounting screws, so here is a airplane part that has actually come down in price. The Spruce 800 number is 1-877-477-7823.
Harold H
Harold H
Hubcaps for 6" Clevelands
Thanks everyone for your assistance....this forum works great.
- wa4jr
Along the same subject line...I have been thinking of taking my wheelpants off and going with just a hubcap. Don't have my parts manual with me here and was wondering what size and thread pitch the main axle nut is? I'll have to replace the main nuts used with the wheel pants with plain castle nuts to clear the hubcaps.
Wheel pants do more than just look good. If you ever taxi through puddles, light mud, etc., they prevent it from being slung up under your wings, into your flap-wells, and all over your tail. They also help keep dings from rocks and gravel off your tail surfaces. (Of course, with heavy mud they're a problem.)
An idea on hubcaps: I have seen the screw-holes in Cleveland wheels buggered up both by stripping out the threads,and from corrosion--possibly dissimilar-metal corrosion from using stainless screws in the aluminum (or are they magnesium? ) wheels. I use nylon screws to hold my hubcaps on,since both the hubcaps & the screws are white it doesn't look funny. If you do go with stainless screws,I would suggest using blue loctite & very little torque,just snug them up.
Last edited by zero.one.victor on Thu Jun 05, 2003 4:34 am, edited 1 time in total.
Was gonna say, they can also be a PIA..... A friend with angahorn wrote:Wheel pants do more than just look good. If you ever taxi through puddles, light mud, etc., they prevent it from being slung up under your wings, into your flap-wells, and all over your tail. They also help keep dings from rocks and gravel off your tail surfaces. (Of course, with heavy mud they're a problem.)
early 182 had his wheel pants fill up with snow one time. Not
a good thing to have upon landing.....
I will probably get arguments here, but small tires tend to do
more damage (mud/gravel/rocks) than big tires do. If you're
going to go sans wheel pants, might as well get 800's (or at least
700's). Bare (naked) 600's are a waste of time and just may do
more harm than good....
Just my personal opinion of course (flame retardant suit donned!).
Bela P. Havasreti
'54 C-170B N170BP
- N3454C
Re:
N170BP wrote:The IP catalog for my B model says:
AN7502-24 Nut - Axle
and it uses a AN380-4-3 Cotter pin.
Bela P. Havasreti
'54 C-170B N170BP
Looks like Textron now says this is the replacement (current) P/N https://ww2.txtav.com/Parts/PartSearch/ ... /AN7502-24
- Joe Moilanen
Re:
Mine were stripped out when I got my plane, I just tapped them out to #10 holes and finished with a bottoming tap. Working great 33 years later. I always put a dab of oil on them when I re-install them for corrosion prevention.zero.one.victor wrote:An idea on hubcaps: I have seen the screw-holes in Cleveland wheels buggered up both by stripping out the threads,and from corrosion--possibly dissimilar-metal corrosion from using stainless screws in the aluminum (or are they magnesium? ) wheels. I use nylon screws to hold my hubcaps on,since both the hubcaps & the screws are white it doesn't look funny. If you do go with stainless screws,I would suggest using blue loctite & very little torque,just snug them up.
4518C
