Heater Cable
Heater Cable
I need a new heater cable--anyone have a part number--1955 170B. Thanks. LBB
From the IPC (which you should own) it is PN 0411090-11 for serials 25373 thru 26038, and PN 0411090-5 for serial number 26039 and on.
But this is common bowden cable available from Aircraft spruce 877/477-7843 and Univair 888/433-5433. I suggest a "ratchet" control type for cabin heat, cabin air, mixture, etc., because it will stay exactly where you place it, oblivious to vibration. This would be the "A-740" model which comes with either black or red knob (paintable tho'.) Specify length (which can easily be shortened in the field) from either 60 or 72 inches.
heater cable
thanks for the reply--i'll do some shopping
LBB
