Step kit
- blueldr
Re: Step kit
Are you referring to the step that is attached at the bottom of the boot cowl or the one iastalled on the wing strut?
- 54170b
Re: Step kit
I installed mine under a minor modification, and there Cessna parts so its fine. Also I added an extra stringer, and a doubler to beef it up. They are necessary for the boot step! also I added a doubler for the handle.
- nmflyr
Re: Step kit
I am adding the step by the strut root, and the handle above it.
- blueldr
Re: Step kit
I have found the best top cowl, stainless steel, hand holds are sold by the world famous IKEA airplane parts department in the IKEA furnature store. They're so good that many people even use them as drawer pulls in their kitchens.
- jrenwick
Re: Step kit
Yep!blueldr wrote:I have found the best top cowl, stainless steel, hand holds are sold by the world famous IKEA airplane parts department in the IKEA furnature store. They're so good that many people even use them as drawer pulls in their kitchens.
Re: Step kit
so how did you bolt the step to the side of the fuselage by the strut root?
Re: Step kit
is there a step for the top of the gear to use for fueling? i have 180 gear.
Re: Step kit
i mean near the top of the gear legs3454terryg wrote:is there a step for the top of the gear to use for fueling? i have 180 gear.
Re: Step kit
The "boot cowl" step rivetted onto that area in later 100 series Cessnas would likely be the best solution for this problem with 180 gearlegs.
Keep in mind a major concern with spring-gear legs is: stress-markings which clamps, tools, brackets, etc. make upon the spring gear which leads/contributes to failures, ....and also beware that anything permanently attached can lead to rust/corrosion and subsequent failure. Epoxy hides cracks.
IN short..this is not something you want to undertake without due caution.
I carry a collapsible/flat step-stools I bought at Pep Boys (in honor of bluElder) which weighs about a pound, lets me step up to check fuel caps, allows elderly/infirm folks a short step-up to the cabin, and also makes a great "seat" at fly-in-gatherings. They are 12" and 18" tall, collapse completely flat and take up virtually no baggage space.
A pair of them were $10 on-sale,regularly less then $15.
I'll try to find a pic to post.
- blueldr
Re: Step kit
A boot cowl step is best given a generous (read maximum) sized, good husky, doubler on the inside of the cowl. Ditto the hand hold. (The C-170 skin just aint beefey enough all alone.)
- Blue4
Re: Step kit
All parts sources notwithstanding, would anyone happen to have a copy of the instructions for Cessna kit AK172-168h ? This is/was the kit that allowed early model 172 owners to retrofit their airplanes with Cessna parts back when they didn't cost a fortune.
I have Cessna parts; I'd just like some drawings and specifications for the doublers so we can make a nice and tidy 337.
This is a very popular mod here in Alaska; its not very "original" looking but it sure is handy. And many Cessna nosedragger pilots expect them since they're standard equipment beginning in the mid-60s models of Cessnas. (My apologies to 180 and 185 drivers, yes, you too have them installed).
If no one has a copy of the instructions, where is a good source? Thanks always.
-Scott
-Scott
- n2582d
- Blue4
Re: Step kit
Thank you VERY much, Gary. I'll post updates.
-Scott
-Scott
