is now at zero,
CHT and EGT are all normal on all 6 cylinders. I make it back and land ok.
Oil temp stayed constant.
After shut down, no oil leak, and 6 qts on the dipstick.
We dissconnect the oil pressure line at the fire wall , and connect it to a calibrated guage,
still zero oil pressure.
We take off the oil pressure line, blow it out, re-install it, and still zero pressure.
We take the line right off , run the engine and just a small amount of oil comes out slowly.
( now I am getting very very worried !!! )
We pull the oil pressure relief valve, clean it up, with some scotch bright, re-install, still zreo pressure.
Next we dump the oil, ( clean ) and cut open the filter. ( The engine has 18 hours on it since we changed the sump )
We find approx 25 specks of continental paint chips, about the size of a pin head.Also we find a small amount of
magnetic metal, which the mechanic feels is from a exhaust guide most likely, or possibly a pump gear. The
metal was quite fine and the total amount would cover the small magnetic about the size of a pencil eraser.
Our plan on Monday is to pull rocker covers to look for a possible bad exhaust guide, and also to recheck
the oil pressure relief valve, as I did not check the seat area of the plunger, first time.
Any suggestions ? Any experience with oil pressure falling to zero ?
My engine ( O-300D ) has 550 hours on it in 4 years, and the oil pressure has always been 40 psi.
One person mentioned to me that if the oil pump quite, the oil temp would not go up as the hot oil
would not be circulated to the temperature bulb. Is this the case ??
I have my fingers crossed John
