engine-carrier
Wolfgang
engine-carrier
Post by Wolfgang »
Hello!
We in Germany can use for a C170 B two engines. Die first is the C145-2. The second is a O-300. About this fact I have a question.
Can I use the same engine-carrier for both engines? Or is the engine-carrier not the same?
The rebuilding of my C145-2 is very expensive and at the moment I can buy a O-300 for smale money in good condition. But my engine-carrier is for a C145-2.
Best regards
Wolfgang
Best regards.
Wolfgang
N1277D
Engine Mount
Post by N1277D »
The engine mount should be the same for both engines. Later model O300s have a 6 bolt prop hub vs the 8 bolt prop hub for the c145. If you have a latter model O300 you would also need to replace the prop
