180 Lycoming STC
180 Lycoming STC
Who currently holds and is still in business to suppply the STC for a 180hp Lycoming conversion? Does anyone have current contact information for the STC holder(s)?
Bruce
Bruce
Harry Dellicker/DelAir
2121 So. Wildcat Way
Porterville,CA 93257
559-784-9440
Don't have an email address or website for DelAir.
There have been other STC's over the years--Avcon/Bush,Doyn,Turner,KWAD,RFB-- for installing the Lycoming O-320,O-340,O-360,IO-360,and even the O-435,but I don't know how many of them (if any) are being marketed these days.
A Lycoming conversion ain't cheap,but I guess it makes a "real airplane" out of the 170,as does the Cont IO-360 or the 220 Franklin. As any old hot-rodder or biker knows, there's no substitute for cubic inches!
559-784-9440
I have read this conversion can cost over 30k. Does anyone have a breakdown of money spent on a conversion. Just wondering how much of this is labor, engine cost, prop, accesories etc,. How many hours it takes to convert one?
I fly mostly floats and skis and could use the bigger engine.
Brian
'56 170B N3532D
'56 170B N3532D
Here's a guess:
STC with mount cowl mod and other parts $6000
Engine field OH outright $15000
Prop and spinner $7500
Misc Governor,vac pump, instruments, etc $3000
Labor depends on how much you can do yourself. I would think that if you had it all done you could sell your old FWF to cover it.
I now have a net of $20k in mine with a fresh engine but I got some good deals and did all the work myself.
Call Harry Dellicker, he's a kick to talk to.
N92CP ("Clark's Plane")
1953 C-180
1953 C-180
Thanks for the information, do you have a rough estimate on the hours it takes to complete the job? Thanks
It's kind of a toss up, sell mine and put money with it and buy a C-180 or spend 20-30k on a conversion. Probably in the long run it would be less expensive to keep the 170.
Brian
'56 170B N3532D
'56 170B N3532D
I have made some phone calls to the STC holders and the cost of conversion looks like this:
STC with all bits and pieces: $9,200
Prop & governor: $9,000 (new)
Engine: $26,000 (New Lycoming)
Total: $44,200
The Continental IO-360 is the same overall cost.
Of course finding a used / OH engine and prop is the key to keeping the costs down. Installing a fixed pitch prop helps also.
If I sell my 170A and add $44,000 to the proceeds I still cannot buy a C-180 in as good condition as my 170A. The added operating costs of a C-180 are an issue also. If the STC holders get the 250-300 lb. gross weight increase for the 170 then a souped up 170 will pretty much match a C-180.
Let's hope my engine stays together while I save my pennies.
Bruce
Total: $44,200
Bruce
A fixed pitch prop negates a lot of the advantages of more hp.
A O360 Lycoming doesn't make 180 hp unless it's running at max rpm.
Why spend $35 grand for only a few more hp?
The C145/O300 only makes about 120 hp at takeoff due to the fixed prop.
A variable pitch/constant speed on this C145/O300 would make it a new animal!
I guess what I'm saying is that I don't think I could get excited about a 180 Lyc without a constant speed. If I were to favor a fixed pitch prop, I'd probably lean more toward a (potentially 210 hp) Continental IO-360/O-360 with one. (Fords/Chevy's, etc.)
I have been thinking about upgrading my '56 C172 to 180hp via Harry's STC. Here is a message I posted recently on the Cessna Owner's Organization website.
What a coincedence. I spoke to Harry at Del-Air a few days ago about this very thing. He has two STC's, one for a fixed pitch prop ($8700) and one for a Constand Speed prop ($9200). Trade-A-Plane has Lycoming O-360-A4M engine for 13.8K to 16.8K but you will need a mechanic to install it, not sure how much that will run. A 172 is a pretty simple plane so lets say 40 hours (which is one week) at $55 per hour is $2200. All that adds up to $28.2K at the high end of the numbers I have listed. Now it may take more than a week to do the swap, I have no idea how long it will take.
George wrote:
"A fixed pitch prop negates a lot of the advantages of more hp.
A O360 Lycoming doesn't make 180 hp unless it's running at max rpm...(snip)...I guess what I'm saying is that I don't think I could get excited about a 180 Lyc without a constant speed."
Generally I agree wholeheartedly, however, an exception might be a plane on floats full time with a long seaplane prop set to hit the 2700 static. It'll never get much airspeed in cruise anyway.
I like the Lycoming but then you can't have too much power so it would be fun to try the IO-360 with the constant speed. I guess then I'd have a true XP huh?
1953 C-180
1953 C-180
And then there's the 220 Franklin conversion (Of course the Franklin & the Continental can't burn car gas. George,that'd kill the deal for you,I know how much you love that stuff.)
And then there's the O-470 conversion,otherwise known as the Cessna 180. And for that there's the Ponk +50 (O-520) conversion. And then there's the IO-520 conversion,also known as the Cessna 185. Then there's the IO-550 conversion,and the IO-540 conversion........Just goes on & on.
IMHO,the Lycoming O-360 seems the perfect match to the 170 airframe,all things-- cargas compatability,fuel burn,price,horsepower,size,availability,track record,etc-- considered. Or maybe the IO-360 Lycoming if you need a smidge more steam.
