Re-wiring
Tim Harter
Re-wiring
Post by Tim Harter »
I thought I remember reading a post on here that broke down how much of each size wire is needed for a rewire. I have a 1954. I tried the search to no avail. I know I can add it up from the electric manual but was going to be lazy and ask.
Tim
gfeher
Re: Re-wiring
Post by gfeher »
Tim, I think this is the thread you were looking for: http://www.cessna170.org/forums/viewtop ... =24&t=6292
If the forum's search engine doesn't find what you want, try Googling it with "Cessna 170" somewhere in the inquiry. Usually Google finds it right away.
Gene Feher
Argyle (1C3), NY
lowNslow
Re: Re-wiring
Post by lowNslow »
If you have a parts manual it has a list of all the wires with lengths and wire gauge.
Re: Re-wiring
lowNslow wrote:If you have a parts manual it has a list of all the wires with lengths and wire gauge.
If you have a B model you will find the wires, lengths and gauge. If you have a '48 or an A model your out of luck though the same wire in a B should work in the early models.
Tim Harter
Re: Re-wiring
Thanks a lot guys! as you can see we have a lot of work ahead of us. Theses are old pictures so it looks a bit better now but still a long way to go.
Tim
bagarre
Re: Re-wiring
Post by bagarre »
Is there an easy way that looks good to label the wires upon replacement?
Re: Re-wiring
bagarre
Re: Re-wiring
Post by bagarre »
I've never had good luck with the write on wrap types. Specially with smaller wires
After looking around, I think I'll try the shrink tube label makers. At around $100, it's not cheap but all the cheap options seem to be, well, cheap.
edbooth
Re: Re-wiring
Post by edbooth »
bagarre wrote:I've never had good luck with the write on wrap types. Specially with smaller wires
I just write on the white shrink tube with a extra fine point sharpie. When shrunk, it's still very legible.
