Fuel Gauges
simon
Fuel Gauges
Post by simon »
I know there have been several posts on the subject, but I couldn't find one with this problem. One of my gauges has been inop, so I took it out. Needle didn't move when I moved the linkage. I thought maybe the needle was corroded/stuck so I took the bezzle and glass apart but the needle moves freely. It seems that somehow it has lost it's magnetism. Does any one know if the needle is a magnet or the "horseshoe" piece on the inside is the magnet. How would one re-magnetize in this situation. The rest of the gauge works great, the cork is even still bouyant.
'53 C170B
3092A SN 25736
Hmmm. Just fooled with my gauges and have one available at home I could check. I just thought the horseshoe was the magnet.
bsdunek
Post by bsdunek »
N9149A wrote:Hmmm. Just fooled with my gauges and have one available at home I could check. I just thought the horseshoe was the magnet.
I agree. The "horseshoe" part is the magnet. An electric motor shop that works with DC motors may be able to re-magnatize it. Otherwise, I would just order one from Aircraft Spruce. You will have to cut the arm to the correct length - just match your existing gage. 8)
Bruce
1950 170A N5559C
