Rudder Bearings
Rudder Bearings
Hi guys, we were working on the tailwheel and decided to pull the rudder for better access. Just like everything else, it opened a can of worms. To make a long story short, does anybody have a source for the bearings. The parts manual calls them SIK-5. I believe they were made by Fafnir. Also, anybody have any experience changing them. It looks like the Hinge/carrier has been peened over to lock them in. Any help would be appreciated. Also, I can't find the lower hinge bolt that goes through the bellcrank called out anywhere in the parts manual. Anybody know what it is supposed to be? As always, thanks for the help.
'53 C170B
3092A SN 25736
3092A SN 25736
call a bearing supply place, they can cross the bearing part number for you, if your friendly Cessna dealer doesn't have it.
to change the bearing, use a socket of the exact size or just smaller than the outside diameter (OD) of the bearing, and a larger one that the small socket will fit into. use a C-clamp and push the bearing through using the small socket as the pusher and the big one as the catcher.
use a clamp to push the new bearing in, and a center punch works well to peen it in for safety.
'56 "C170 and change"
'52 Packard 200
'68 Arctic Cat P12 Panther
'52 Packard 200
The bearing is a Fafnir SIK-5, still available from Cessna and some others, for outrageous prices. I have one NOS, complete with the NOS bearing support if you run into difficulty. I'd want a fair price for it, tho'.
