Leaking Wing Sump
Re: Leaking Wing Sump
Don't forget to take a photo and post it.
MIles is right . Buy one extra keep a at least two sealed o'rings on hand and just swap out sumps. I take my with me in my tool bag because these things will always leak at the wrong time and place..Gary
Speaking of gascolator valves, mine tends to be wet. Please tell me how you took it apart to replace the o-rings,Chris Christensen wrote:I also changed out my sump valves once, for a fairly stiff price.
Examined both and found two conditions:
1- Old shriveled up little itty-bitty O-ring that did not seat well.
2- Small / fine particles UNDER the O-ring which kept it from seating.
Now, I was obviously able to find replacement drain valves, but not JUST the O-ring.
My solutions was to research O-rings for the best fuel friendly versions I could come up with.
Bought a bag of 10 or 20 for a couple bucks.
Replaced the O-rings on my two older drains.
Now I do not have to spend money on new drains.
I was having to change them out every month or so for a while
after have installed the modified Long Range Tanks.
Seems that the problem is over with as of late.
YES, we did everything we could think of to clear any debris out of the tanks before re-installing them. They got a good air-hosing, water-hosing, etc., but still kept getting finite little particles under the O-rings for several months.
PS: it is the same O-ring that is used on the gascolator valve, at least is is on mine.
Bruce
1950 170A N5559C
1950 170A N5559C
- Curtis Brown
That's a good safety list.
Especially # 7
Now that's funny...I don't care who you are you got to think that's funny.
Especially # 7
Curtis
1950 A model 1256D
1950 A model 1256D
