Empty Spot in Instrument Panel
- MoonlightVFR
I am going to take a few new passengers up. Never been in small GA plane.
A/C is 54 C170B, S N 25433 mfg JUly 1954.
I want new passengers to Enjoy flight and not worry about missing instruments in panel.
At far right of panel above the glove box I have two (2) of the smaller mounting holes.
My question to the forum is What would normally go there?
I do not need any additional instruments.
Are false filler panels available?
G
G
gradyb, '54 B N2890C
- n2582d
Re: Empty Spot in Instrument Panel
Grady,
Although no simpler part could be made for your plane you can still buy the genuine Cessna cover plate, p/n 0713200-7, from Preferred Air Parts. A cheaper alternative would be a cover from Aircraft Spruce. Take a look at figures 44, 77, 79 and 80 in the IPC to see that optional instruments included a suction gauge, CHT, manifold pressure gauge and carburetor temperature gauge.
Often for new passengers a sense of control will help eliminate the fear of flying. One idea might be to install a dummy ON-OFF switch in a blank hole and label it “MCAS”. After takeoff initiate phugoid ...
- edbooth
A piece of aluminum or plastic and flat black paint works great.
- Ryan Smith
You’re a sadistic man, Gary!n2582d wrote:Grady,
That’s why I like the piano key panel...not a lot of holes to worry about filling.
Blanked-out inst. holes might raise as many questions as open holes... maybe not tho'. I have a few Cessna Royalite false panels with "blanks" from other airplanes sitting in the hangar attic which you're welcome to. PM me which address to mail them to. When are you planning the flight? If very soon, you might follow Ed's advice.... simply paint a square of aluminum flat-black and slip it behind the panel. You can either mount it permanently or use velcro.MoonlightVFR wrote:I am going to take a few new passengers up. Never been in small GA plane.
G
- 4583C
If you’re really a glutton for punishment you could just make a new one. I changed the size and shape of several holes to suit my instruments, and deleted a couple of holes I no longer needed.
here
More details You do not have the required permissions to view the files attached to this post.
- kaufman
Although not the cheapest option, I filled in the last hole (far right side) in my panel with a slip indicator. I found it a very useful and informative instrument for curious passengers. With just a little explanation about coordinated flight and how to " kick the ball to the center" the passenger gets confidence that controlling an airplane is more intuitive than technical, and just plain fun. A more advanced passenger can also serve as autopilot if I want to take a little break, something they cannot do smoothly in turbulence without command of that axis.
