1949 170A Toe in & camber
anyone know the toe in and camber for 170A with original gear and wheels ??????????????
- gfeher
Re: 1949 170A Toe in & camber
Gene Feher
Argyle (1C3), NY
Argyle (1C3), NY
That information and how to check it, is located in the Cessna 100 series service manual I believe
Zero camber and toe in at 2000 lbs. Heavy duty “contractor” plastic trash bags are a good substitute for greased plates has been often suggested, as the plastic slides/twists readily when the airplane is rolled onto them indicating misalignment.
