CARB HEAT REPAIR KIT
rossplanes
Post by rossplanes »
Hi,
I own a 170B with a Lycoming 0-360 installed with an Avcon STC. I would like to purchase a carb heat repair kit for the air box from McFarlane. The McFarlane Part number CCH-KT-4 "LOOKS" like the right one. Would appreciate any help/advice!
Thanks, Charlie Ross
Re: CARB HEAT REPAIR KIT
Charlie… I’m certainly in support of anyone/everyone keeping their airboxes iin good condition. Not to mention the air leaks that defeat any attempts to supply Filter-Air to the engine….. If a loose part or nut or cracked piece of sheet metal is sucked up onto the engine…it will NOT be a good flight.
However, I took the easy way out. I mailed my goofy-designed 172-C ratty airbox to Del Lehmann in Mena…and a week later…it was returned in “like new” condition for only a couple hundred AMUs. Some of the best money I’ve ever spent. :wink:
rossplanes
Thanks George,
The hole in the bearing on one end of the carb heat valve shaft has worn into an oval allowing the shaft to vibrate and
break into 2 pieces. I wonder if Del could repair that, and if so would it be cheaper that a Mcfarlane kit?
Charlie
DaveF
Post by DaveF »
My Avcon airbox was repaired with bronze bushings from McMaster-Carr or similar. It's been a few years and I don't remember the source, but they were only a few dollars each and have held up ok.
McFarlane offers Teflon bearings for some airbox repairs.
