Airframe Overspeed Vne
Re: Airframe Overspeed Vne
johnsunday wrote:Brad,
Only lasted for a few seconds, 10 at most. Gonna do Del's inspection recommendation this week-end.
Your airspeed indicator could be off that much. If no turbulence was present, the recovery was smooth,....a visual inspection for wrinkled skins on the aft-lower wing and a check for cracks/wrinkles on the horiz. stab/rear bulkhead would probably be sufficient to reassure you.
johnsunday
Post by johnsunday »
Brad,
You got that right.
Robert Eilers
Post by Robert Eilers »
John - just to be certain. What speed are do you consider VNE to be - 140 or 160 IAS?
johnsunday
Robert,
I'll have to go to the hanger and check.....Whatever the redline on the airspeed indicator is at....
